PMAG not working in mixed mode NSC
  • 6 November 2023
  • 19 views
We use zemax to simulate a galvo scanner geometry in mixed mode NSC. Almost all seqential analyses work in mixed mode.
However the paraxial magnification gets messed up. I am pretty certain this is due to the beam beeing turned in the nsc component. In the depicted example an object point (0,1) gets imaged to (-1,0).
Apperently this can be corrected by setting the “Exit Tilt Z” for the non sequential component to a value that object points on the x-axis are imaged to image points on the x-axis.
However the documentation says “The radial magnification, being the ratio of paraxial image height to object height”.
My impression is, that zemax internally uses vector components instead of “heights”.
Be the first to reply!
