Non-sequential multiconfiguration waveband tracing
  • Mar 1, 2021 3:41 PM UTC
  • 368 views
James.Fry
I have a non-sequential component model with two configurations.  The wavelength bands in the two configurations are different as is the aperture size.  Everything else is otherwise the same.  If I 'Ray Trace' with analysis rays, do both configurations get traced and, if so, is there a way to filter out one of the configuration's ray traces via the filter string?
James.Fry
  • Mar 1, 2021 3:42 PM UTC
X_ WAVERANGE (n, a, b)?
Hui Chen
  • Mar 1, 2021 4:17 PM UTC
Hi James,
The ray trace happens one configuration at a time. The results you see on the detector is the trace results from current configuration. Now, if you have multiple wavelengths in a single configuration, then you can certainly use filter string, like X_ WAVERANGE (n, a, b), to filter rays based on their wavelengths.
Hui
James.Fry
  • Mar 1, 2021 4:43 PM UTC
Thanks for the clarification.
