non-sequential mode: hyperhemispherical object
  • Oct 10, 2024 9:37 AM UTC
  • 5 replies
  • 364 views
Corkas
Hi there,
I try to model a hyperhemispherical object in the non-sequential mode, however, Zemax won’t let me to do so. I get an error saying “cannot create object because there are too many faces in the source objects”. I tried to use the Boolean operation and substracted a zylinder object from a sphere. This works for truncated spheres until a hemisphere results. If I shift the zylinder further and the result would be a hyperhemispheric object the error occurs.
Is there another possiblity to create a hyperhemispherical object?
Many thanks for your help! :)
@Corkas
Could you use a Standard Lens object with a Radius equal to the Thickness?
Any chance you can share your file for troubleshooting? The error seem related to a Source as well, do you have a Source within the hemisphere?
dkominsky
  • Oct 10, 2024 1:52 PM UTC
I’ve done it in Non-seq mode, with the following (e.g. a hyperhemisphere with 4mm radius that is 4.3mm thick:
Standard Lens:
Radius1 = 0
Conic 1 = 0
Clear 1 = 4.0
Edge 1 = 4.0
Thickness = 4.3
Radius 2 = -4
Conic 2 = 0
Clear 2 = 4
Edge2 = 4
Hope this helps.
Dan
Corkas
  • Oct 10, 2024 2:12 PM UTC
thanks a lot for your quick responses @David.Nguyen @dkominsky !
If I understand the standard lens correctly, it can only create hemispheres but I need a larger portion of the sphere. I solved the issue the following way:
Cheers!
  • Oct 10, 2024 3:11 PM UTC
Hi Corkas,
Depending on the complexity of your system and the speed needed for ray tracing, you can just remove the Boolean Native and use non-sequential mode’s nesting rule:
So as long as the Cylinder Volume is below the Sphere and the Cylinder Volume doesn’t have a material (i.e., the material is Air), then you’ll have your hyperhemisphere and it will most likely ray trace faster than a Boolean Native.
Berta.Bernad
  • Oct 15, 2024 9:37 AM UTC
With the Standard Lens or Standard Surface if the clear semi-diameter is negative, then the surface will become hyper-hemispheric:
