Nominal Criteria cannot be computed, during tolerancing
  • Jun 17, 2020 3:26 AM UTC
  • 761 views
Hui Chen
  • Jun 17, 2020 3:48 PM UTC
Hi Brian,
I didn't see any file or description associated with your post. Could you please provide a bit more context on the issue? This error message is usually seen during tolerancing when OpticStudio tries to compute the tolerancing criterion in your nominal system but failed.
There are many factors that could cause this error message, for example, the tolerance values selected, the tolerance criterion specified, the Sampling for computing the criterion, the compensators chosen. If you still see this issue, would it be possible for you to share the file so we can take a look? You could also open a case with us so we can move this to a private discussion.
Hui
  • Oct 20, 2023 4:32 AM UTC
Ran across this problem again, but solved it this time. The problem lies with the COMP and the min/max values. It is a delta compensation not the actual min and max values of the compesator which was what I was using.  A user error as usual. -Brian
