Multi configuration operands for refracrtive index
  • Apr 4, 2023 12:22 PM UTC
  • 5 replies
  • 658 views
Hi all,
Is there a way to write a zpl file for making 2 configuration in NSC mode, while changing the refractive index of one of the object? Something like this:
conf 1:
a = n-bk7
    SETNSCPROPERTY 1, 6*i-5, 4, 0, ADF505
    SETNSCPROPERTY 1, 6*i-4, 4, 0, a
    SETNSCPROPERTY 1, 6*i-3, 4, 0, ADF505
    SETNSCPROPERTY 1, 6*i-2, 4, 0, a
    SETNSCPROPERTY 1, 6*i-1, 4, 0, ADF505
    SETNSCPROPERTY 1, 6*i, 4, 0, ADF505
conf 2:
a = s-lah98
Nadav
Hi Nadav,
I’m not sure I understand your point. Have a look at the Help File for SETMCOPERAND (The Programming Tab > About the ZPL > KEYWORDS (about the zpl) > SETMCOPERAND ). The general syntax for SETMCOPERAND is:
SETMCOPERAND row, config, value, datatype
In the line:
SETMCOPERAND row, 0, object, 1
You can see that the config is 0, which means the value changes depending on the datatype. Since datatype is 1, value is the first parameter of NGLS, or the Object #.
Does that make sense?
Hi Nadav,
In the Multi-Configuration Editor, you have an operand called NGLS for the material type for non-sequential objects. In ZPL, you can create, and modify a Multi-Configuration operand with INSERTMCO, and SETMCOPERAND. With your example, you could do:
# Define row number for a new NGLS operand
row = 1
# Define object number that will be attached to NGLS
object = 4
# Insert a new operand in the first row
INSERTMCO row
# Change the new operand to NGLS
SETMCOPERAND row, 0, "NGLS", 0
# Update NGLS to apply to your object of interest
# Insert an additional configuration
INSERTCONFIG 1
# Set Material for Config 1
SETMCOPERAND row, 1, "N-BK7", 0
# Set Material for Config 2
SETMCOPERAND row, 2, "N-SF1", 0
I hope that makes sense.
The rest of your code with the SETNSCPROPERTY seems identical in both configurations why do you need to repeat it twice?
  • Apr 9, 2023 4:02 PM UTC
Hi David,
Thanks for the quick and detailed answer.
NGLS work also for pure NSC mode?
Nadav
Hi Nadav,
Yes it does. I think NGLS was always intended for non-sequential mode.
  • Apr 13, 2023 9:57 AM UTC
Hi David,
I am trying to run your code but it seems the “SETMCOPERAND row, 0, object, 1” control only the surface number(which in pure NSC should be 1) and not the object number.
Nadav
  • Apr 13, 2023 10:52 AM UTC
Hi Nadav,
In the line:
