Maximum Number of NSC Editor objects
  • June 25, 2021
  • 107 views
Kaia.Williams
Is there a maximum number of objects that can be added to the Non-Sequential Component Editor? I'm looking to programatically add an extremely large number of objects to the editor (>2500) using ZOS-API. The vast majority of these objects (~2100) will be arrays referencing another object or objects, and as such will not take up as much memory.
Thanks!
Hi Kaia,
I'm not aware of such a hard-coded limit. I'd be curious to hear if there is one actually.
I believe the limit is going to be dictated by your hardware (memory).
Hi Kaia,
