ISO Drawing for Biconic Zernike Lens
  • November 23, 2021
  • 250 views
amarandi
Hi everybody,
i am trying to export an ISO Drawing of my lens, which consists of two biconic zernike elements. But the Drawing Element in the ISO graph shows the lens as two surfaces even i choose “show as: Singlet”. Is there any solution to get the lens drawing as shown in 3D layout or it is the zernike surface Bug/problem in Zemax?
best regards,
Ata
Best answer by amarandi
so now have my answer. Problem was the semi diam in the lens editor. I defined the semi diam as a fixed param and then the problem was solved. :)
amarandi
  • 13 replies
  • November 24, 2021
