Image Simulation with a curved image plane
  • Sep 17, 2021 6:45 PM UTC
  • 685 views
Hi all,
Does anyone have experience using the image simulation analysis tool, but with a curved object plane and planar image plane? Is this something Zemax would take into account, or should I superimpose my field points onto a planar surface?
Best answer by Angel Morales
Hi Erin,
Thanks for your post on our forums!
For the Image Simulation tool, one of the components of the analysis is the computation of a PSF Grid, which evaluates some array of PSFs across the field of view as defined by your input JPG/BMP/etc file. This PSF Grid is computed through real ray tracing results, which begins at your Object surface. So, if your Object surface is curved, then the off-axis field points will begin their ray trace in generating the PSF Grid at whatever Z-offset there is from the curvature of the Object surface. We can see this in the PSF Grid results from Image Simulation for the following system:
When Image Simulation performs the convolution step, OpticStudio will convolve the PSF Grid shown above with your input image file (so, in Config 2, the off-axis points will degrade in image quality due to the broadened PSFs):
Let us know if this helps clarifies things or if you have any more questions here!
Angel Morales
  • Sep 21, 2021 11:40 PM UTC
Hi Erin,
