How to use SETSURFACEPROPERTY to set TILT Z for a COORDINATE BREAK SURFACE
  • August 27, 2024
  • 339 views
This should be pretty simple to do but I can’t figure it out.  In a .ZPL I am trying to set the value of the Tilt about Z for Coordinate Break surface #12.  It seems that this is PARAMETER 5.
So I use the command:
SETSURFACEPROPERTY  12, 5 123.456
nothing happens,
It is so simple in CodeV.
CDE S12 123.456
So archaic that Optic Studio uses “parameter number” instead of a simple keyword like ADE, BDE, CDE for tilt. CDE is tilt about Z axis (rotation)
Best answer by MichaelH
Hey Harvey,
For someone coming from CodeV, I can see how this can be challenging, but you also needed to learn what ADE, BDE, CDE was for CodeV when you first started...this is no different.
  • For the ZPL, you can use either SETSURFACEPROPERTIES or SURP.
  • To change an extra data parameter (anything to the right of the TCE column), you need to use the PARM (10) code.
  • To set the new number, the Value1 should be 123.456
  • To change the Tilt About Z, the Value2 should be 5
So the final code should be:
SURP 12, 10, 123.456, 5
  • August 27, 2024
Hey Harvey,
