How to use Matlab or Python to use ZTD tolerance analysis data?
  • Nov 11, 2021 12:11 PM UTC
  • 8 replies
  • 1331 views
I know I can manually load the ZTD file using Tolerancing data viewer and copy the data to excel.  I would like to automate the procedure using Matlab or Python since I have more than 50 ZTD files. Thank you very much.
Hi Yao,
It is tricky cause I don’t think the Tolerance Data Viewer is implemented in the ZOS-API. However, the *.ZTD file can be opened with a text editor like Notepad++.
Although there are some encoding issues, and perhaps binary content, most of the file seems fine. You could try to directly read the *.ZTD file with MATLAB/Python, and see what it gives you.
Let me know if that works for you.
  • Nov 12, 2021 10:14 AM UTC
Hi Yao,
  • Nov 15, 2021 5:09 PM UTC
Hi David,
Thanks for the suggestion. I  checked the Monte Carlo section of the ZTD file, unfortunately, this section is encrypted.:joy:
Angel Morales
Hi Yao and David,
I just wanted to step in here and make a quick comment that the Tolerancing Data Viewer is implemented in the ZOS-API :slight_smile: You’ll need to use the IToleranceDataViewer interface:
Properties of ToleranceDataViewer include Monte Carlo data, Sensitivity data, etc.:
So, I ran a tolerance on one of our sample files to get the following Monte Carlo data:
With the following code in MATLAB:
tolDataView = TheSystem.Tools.OpenToleranceDataViewer();
tolDataView.FileName = "C:\ … \Yao_CookeTripletTest.ZTD";
tolDataView.RunAndWaitForCompletion();
MCData = tolDataView.MonteCarloData;
MCDataValues = MCData.Values.Data.double;
We can get the values for each column in the Monte Carlo data:
The column headers are stored as the Monte Carlo metadata, which you can pull per-column with GetMetadata():
Let us know if we can be of any more help -- thanks!
Thank you for correcting me @Angel Morales!
alexander_dumont
Hi all
Does this situation still work? I am tying to do the same thing using C# ZOS-API, but in my case, when I try to do
 var tolDataView = TheSystem.Tools.OpenToleranceDataViewer();
I get a system null reference exception which means I can't access my MC data.
Hi Alexander,
This piece of code works for me in Python:
TolDataViewer = TheSystem.Tools.OpenToleranceDataViewer()
TolDataViewer.RunAndWaitForCompletion()
print(TolDataViewer.SensitivityData.NumberOfResultOperands)
TolDataViewer.Close()
And it returns the correct number of operands. Therefore, I have no reason to suspect this shouldn’t work in C#. Are you able to share more of your code with us?
Hi all
I am having the same issues.
Zemax-Version 2023 R1.02 accessing the API through Mathematica.
tol = primarySystem@Tools@OpenTolerancing[];
tol@RunAndWaitForCompletion[];
tolV = primarySystem@Tools@OpenToleranceDataViewer[]; (*nothing happening*)
NETTypeInfo[tolV] (*Shows error "NETTypeInfo: Object is null"*)
  • Feb 9, 2026 7:18 PM UTC
​@simon.schroeder_01 Hi Simon, not sure if you’ve solved this issue, but I suspect you’re running into the limitation of the ZOS-API where you can only have 1 tool open at a time.  If you compare something in the Tools interface in the ZOS-API to the corresponding feature in the GUI, you’ll notice you can only have 1 tool open in the GUI.  The tool is a modal dialog, meaning you cannot interact with any other part of OpticStudio until you close the tool.  The same is required in the ZOS-API.
I would suggest to use tol@Close[] (or the equivalent Mathematica syntax) before calling the OpenToleranceDataView:
tol@Close[];
