How to set up the polarization state seperately for object and reference beam of recording a hologram?
  • August 14, 2022
  • 149 views
ztystar
Hi all,
I am trying to model a hologram to analyze its diffraction efficiency in Zemax. However, I am curious how to seperately set up the polarization state of the object and reference beam, for example, one is s-polarized, the other one is circularly polarized?
Kaden
Best answer by Jorge L
Hi Ztystar,
I don’t know why you would like to go for such a different polarization but the only thing that comes to mind is using a OFH. Since you have to create two separate files in order to create a OFH you could set different polarisation states for each ones and combine them later.
I have never done it in the way ask so I wouldn’t know if the results allow you to retrieve the DE correctly but I think it’s worth a shot.
Hope this helps.
Jorge.
Jorge L
  • September 13, 2022
Hi Ztystar,
Hope this helps.
Jorge.
