How to perform tolerancing with composite surfaces
  • 27 February 2023
  • 28 views
Hey friends, I am wondering how to set up tolerancing using composite surfaces.
Basically, I have a composite surface configured with the designed curvature of a lens as the base, and the Grid sag file generated based on errors I measured from a lens using profilometry. I would like to see if I have multiple times of the error adding on the base, how bad the lens performances will be. I was trying to use TIRR but I was confused about how to set it up. Can anyone suggest? Tutorial on ‘Tolerancing irregularity with Composite Surfaces’ was not very clear on this to me.
Be the first to reply!
