How to optimize Binary 1 phase to be like a prism function?
  • April 20, 2021
  • 355 views
I'd like to set a field angle in object space,e.g., 10 deg.
After Binary 1, the rays would be 0 deg.
What merit function can we apply for this work?
Best wishes,
CM tsai
Katsumoto Ikeda
Hi Cheng-Mu, two settings you will need:
  1. Set to 'Afocal image space' in the Aperture setting in the System Explorer
  2. Open the Optimization Wizard, set the Optimization Function to 'Angular'. The wizard will auto-generate the merit functions you will need.
I hope this helps.
-Kats
