How to check the spot size when wavefront error is changed?
  • July 6, 2023
  • 102 views
YoungDae Yim
I want to check the spot size when wavefront error of Mirror’s surface is changed.
(at λ/10, λ/20, λ/30, λ/40, λ/50)
How to change the wavefront error of Mirror’s surface?
Best answer by Mark.Nicholson
I’d make the mirror surface a Zernike or Irregular surface and just program the LDE with the desired wavefront.
