How is a MIRROR without a coating handled?
  • February 22, 2019
  • 8 replies
  • 404 views
Allie
  • 343 replies
I've placed a MIRROR into my system, but I haven't defined a coating for it. How is its reflectivity defined?
Best answer by Allie
If a surface or object has the material type MIRROR, and no coating is specified, then the surface is assumed to be coated with a thick layer of aluminum, with an index of refraction 0.7 - 7.0i. The aluminum layer is assumed to be thick enough that no light propagates past the layer.
This means that an uncoated mirror surface has a reflectivity of less than 1, just as an uncoated refractive surface has a transmission of less than 1.
Allie
  • 343 replies
  • February 22, 2019
jsung
  • 27 replies
  • October 16, 2024
For CAD objects I don’t want to make it mirror material in the layout editor as only some part of it is reflector surface most of time.
So if I choose “Reflective” in the “Face Is” line under Coat/Scatter property of object, is that working like thick Aluminum surface?
What if I want to apply certain reflectivity values different from Aluminum on that surface. Should I leave the face as Reflective and choose one of I.xx coatings in the list?
  • 1130 replies
  • October 17, 2024
@jsung
At the bottom right of an Object Properties, you’ll find a blue exclamation mark icon, which generally brings you to the relevant part of the Help File.
If you read the section Face Is you’ll find the following.
If you want a specific reflectivity, use a coating. The Coating takes precedence over Face Is Reflective.
You can make a dummy system, such as a Source Ray (1W) reflected on the face of a Rectangular Volume and onto a Detector.
If you use Face Is Reflective and no Coating you get (with Use Polarization in the ray trace):
If you use Face Is Reflective and Coating I.0 you get (with Use Polarization in the ray trace):
Note that you can also have a Coating with Face Is Object Default, and if the Rectangular Volume doesn’t have a material (as in my example), or is made of a refractive material, you would have transmitted rays go through the Rectangular Volume (here I used I.50):
jsung
  • 27 replies
  • October 17, 2024
Thanks Daivd for answers to both of my questions yesterday.
Yes, I looked at the F1 help on the bottom right on this and understand how “Reflective” face would work from coating properties. Wasn’t just sure how that would work when combined with coating file.
So if coating like I.50 is applied on reflective face of transparent material we would have both reflective and transmitted rays? I would test it myself, but just got curious.
  • 1130 replies
  • October 17, 2024
@jsung
No you wouldn’t, the moment you have Face Is Reflective, this part of the Help File applies:
As you can see at the bottom of my post. You need to have Face Is Object Default and a transparent material to get transmitted rays.
Let me know if this isn’t clear.
jsung
  • 27 replies
  • October 17, 2024
Thanks. Seems I missed that phrase in the help. that makes sense.
What if I want to have specific reflectivity instead of just thick aluminum. Can I apply some coating with specific R values on that reflective face or should that face be object default for such coating? In other words reflective face makes just thick aluminum surface regardless of coating file?
  • 1130 replies
  • October 17, 2024
@jsung
It seems I wasn’t clear with my first reply.
If you have Face Is Reflective AND a coating, such a I.50. Then, it is the coating that is considered and not the thick aluminum.
Let me know if this is clear.
jsung
  • 27 replies
  • October 17, 2024
Yes, all is clear now. I missed some of your phrases in the original reply. Also I did my own test in the Zemax NSC mode. Thanks.
