How do you use the System Check feature?
  • Jul 6, 2020 9:38 PM UTC
  • 186 views
When should you use the System Check button, and what type of errors can it check for?
System Check is a simple diagnostic tool that is helpful for any system you design. It’s easy to use, just click the System Check icon in the Diagnostic portion of the Set Up tab, and it will report some common errors and warnings, alongside approximating the memory usage. It can be used anytime during the design process, but is generally most useful when you are trying to evaluate a design form before (and after) fine tuning the lens. This is a sample output from running the System Check on the Double Gauss 28 degree field sample lens that ships with OpticStudio.
Errors notify you of flaws with your system’s set up that need addressing, while warnings denote conditions that are acceptable, but that you may want to check. Trivial warnings are used for valid though unexpected conditions, such as using an obsolete glass, you may wish to verify. The System Check cannot identify every possible error, but it does provide a quick and useful tool for evaluating your design.
Thanks for posting this Sarah. This feature is, in my view, underutilized and it's good practice to use it every day to prevent something unexpected from happening.
In particular, Errors represent Stop! Do Not Pass Go, Do not collect $200 conditions which MUST be rectified.
