How do I optimize hologram modulation for high diffraction efficiency?
  • May 13, 2021
  • 130 views
I am modeling Holograms in non-sequential mode.  I want to optimize recording angles and index modulation to optimize the diffraction efficiency and output angle of the reconstruction beam.  I have not found an example for making index modulation a variable.
yuan.chen
  • May 18, 2021
Hi Deanna,
You can use the NPRO to set these parameters as variable to optimize.
The operand you could use to obtain the efficiency is NSDP.
I attach you an optimized version modified from the Non-sequential example 3 of the article:
Simulating diffraction efficiency of a volume holographic grating using Kogelnik’s method
https://my.zemax.com/en-US/Knowledge-Base/kb-article/?ka=KA-01893
You can find a macro in the article attachment that can populate all parameters in MCE and pick-up the values between Reflect and Transmit.
Please let me know if you have follow-up questions about this process, and I'll be happy to help!
Yuan Chen
Optical Engineer
yuan.chen@zemax.com
