How can I model a cone in non-sequential?
  • Jul 3, 2020 1:06 PM UTC
  • 474 views
Berta.Bernad
This can be done with the Elliptical Volume object, setting either the Front R or Back R to be a really small value (1E-6). Or you can also use Part-Designer; you just need to use one of the pre-defined shapes and save it as a .ZPO object:
Once done, you can import this object in the Non-Sequential Component Editor, and apply different properties or coatings to its faces:
