Expose part designer rotation
  • December 13, 2024
  • 107 views
John.Hygelund
The zemax part designer has a ‘Expose Point’ that allows the sketch point to be directly modified and optimized from the non-sequential component editor. I’d like to do the same with the angle in a ‘ROATE’ command in the script. Is that possible? Or is the another approach that I should use?
Thanks in advance for any help,
John
Best answer by John.Hygelund
I found it, use of the script declaration “PARAMETER”
John.Hygelund
  • December 14, 2024
