Detector rectangle problem
  • Sep 20, 2024 8:11 AM UTC
  • 263 views
MarcoVentura
I have created two Detector Rectangle objects to check the beam shape at different planes. I set them with different size and pixelization (one squared and one rectangular). However in the detector viewer i keep seeing a much bigger detector area, always with X and Y coordinates spanning from -90 to 90 for both the axis and detectors. Moreover none of them has that dimension. Why do i see such an effect?
Marco
Best answer by Jeff.Wilde
@MarcoVentura
Sounds like you may have the detector set to display Radiant Intensity (which is power per unit solid angle):
By default, the detector will then display results from -90 to +90 degrees.
Instead, you may be more interested in the Incoherent Irradiance (which is power per unit area).
Yang.Yongtao
  • Sep 25, 2024 4:47 AM UTC
hi Macro
 it will be better to upload your data to let others have a check
best regards
Yang
  • Sep 25, 2024 7:08 AM UTC
@MarcoVentura
