Converting a Zemax file into a file readable by the CODE V software
  • March 21, 2024
  • 5 replies
  • 299 views
Aniello
Dear All,
Do you know if it is possible to convert a Zemax file into a file readable by the CODE V software?
Thank you in advance for your help.
Aniello
Best answer by Andrey.Pravdivtsev
Run CODE V, start the macro and select zmx file to convert. It should read data and insert it into CODE V.
Sometimes there can be errors.
If I correct there was zemaxos_to_cv.seq macro that can directly read zmx file.
Aniello
  • March 22, 2024
Dear Andrey,
Could you tell me more?
When can I find that macro ?
Thank you,
Aniello
Hi Aniello,
It was in CODE V: Tools - Macro Manager - Sample Macros - Utilities
Aniello
  • March 22, 2024
Hi Andrey,
My question was how to convert a Zemax file into a Code V file.
The other way (from Code V file to Zemax file), I know how it works.
Thank you,
Aniello
