Converting a Zemax file into a file readable by the CODE V software
  • 21 March 2024
  • 5 replies
  • 103 views
Dear All,
Do you know if it is possible to convert a Zemax file into a file readable by the CODE V software?
Thank you in advance for your help.
Aniello
icon
Best answer by Andrey.Pravdivtsev 22 March 2024, 08:31
Userlevel 3
Badge
If I correct there was zemaxos_to_cv.seq macro that can directly read zmx file.
Dear Andrey,
Could you tell me more?
When can I find that macro ?
Thank you,
Aniello
Userlevel 3
Badge
Hi Aniello,
It was in CODE V: Tools - Macro Manager - Sample Macros - Utilities
Hi Andrey,
My question was how to convert a Zemax file into a Code V file.
The other way (from Code V file to Zemax file), I know how it works.
Thank you,
Aniello
Userlevel 3
Badge
Run CODE V, start the macro and select zmx file to convert. It should read data and insert it into CODE V.
Sometimes there can be errors.
