I’ve just tested the new "Convert to Project Directory" feature with a design file using scripted tolerancing.
- I noticed the browsing dialog box (which appears to let the user select the project folder) does not let you create a new folder by simply inserting a new name. The user is forced to right-clic and create a new folder manually, then select it.
![](https://uploads-us-west-2.insided.com/zemax-en/attachment/a13bb9ce-a9a1-4633-9917-f28ad8761054.png)
- the new project directory which is created misses some essential files: .MF , .TOP , .tsc
