Compensators move out of limit
I am modeling an asymmertrical system for laser line excitation. The symmetry is broken by a Powell lens to create a top-hat illumination on the sample. The last element is a microscope objective (paraxial surface) after which the beam somewhat evenly irradiates the image plane along x-plane and is close to diffraction limit along the y-plane.
I began tolerancing the system, includes a zoom triplet, and cylindrical afocal beam expansion and etc. I hope to achive diffractin limit along the y-plane, to do so i set two elements as compensators. When i set y-spot for tolerance criterion it seems to be working, however if i set the merit fucntion, that is defined for RMS y-spot, the compensator moves way out of its working limits and gives better (but false) results.
Anybody can explain what is the difference and what part am i missing?
Thank you,
Zsombor
Part of the result:
Compensator: Thickness 8, Min = -1,0000, Max = 1,0000
Compensator: Thickness 22, Min = -0,5000, Max = 0,5000
WARNING: Boundary constraints on compensators will be ignored.
Criterion : User defined merit function
Mode : Sensitivities
Optimization Cycles : 5
Nominal Criterion : 0,00117646
Estimated Performance Changes based upon Root-Sum-Square method:
Nominal Merit Function : 0,00117646
Estimated change : 0,00686855
Estimated Merit Function : 0,00804501
Compensator Statistics:
Thickness Surf 8:
Nominal : 9,924658
Minimum : -2,262563
Maximum : 29,530714
Mean : 9,800469
Standard Deviation : 3,409756
Thickness Surf 22:
Nominal : 12,660230
Minimum : 10,268682
Maximum : 80,473917
Mean : 13,678104
Standard Deviation : 6,776885
End of Run.
Be the first to reply!
