Cannot compute MTF for zero weight
  • December 12, 2023
  • 68 views
s.ng
When I try to run MTF analysis, I get a Zemax error message:
Cannot compute MTF for zero weight,
What is the reason for the error?  Where is the zero weight?
All my field weights are 1.
Thanks.
Can you see a spot diagram for this system?
I think a screenshot can help to understand your issue.
Kevin Scales
  • 185 replies
  • December 20, 2023
Can you share the system on the forum or open a case? I could not reproduce this problem, but if we could see the system we might find the solution. Thanks.
