Can't set reference via API for Geometric Image Analysis
  • September 15, 2024
  • 61 views
John.Hygelund
I’m having trouble setting the reference to Chief Ray via the API for a Geometric Image Analysis
below is what I have in Matlab, everything works but the highlighted line
Any help will be greatly appreciated!
@John.Hygelund
This works for me in Python:
geom = TheSystem.Analyses.New_GeometricImageAnalysis()
settings = geom.GetSettings().__implementation__
settings.Reference = ZOSAPI.Analysis.Settings.ReferenceGia.ChiefRay
geom.ApplyAndWaitForCompletion()
Ignore the __implementation__, this is a peculiarity of Pythonnet I believe. The line:
Should work in MATLAB. Whenever a setting is implemented as a drop-down menu in the user interface, you should expect that an Enumeration is used in the ZOS-API. This means, the corresponding setting is probably not a string such as “Chief Ray”. Instead, it should be coming from a list of predefined values.
Also, in your code you wrote ReferenceGia, this is a type, the property is Reference. I hope this helps.
  • 1135 replies
  • September 16, 2024
@John.Hygelund
John.Hygelund
  • 71 replies
@David.Nguyen ,
Thank you for the support, your example works in Matlab.
I appreciate you explaining the enumeration for the drop downs.
Thanks again!
