Beam splitter coating in mixed mode
  • June 16, 2021
  • 61 views
Hi all,
Can coating like beam splitter be defined in mixed mode?
I try to define them like in full NS mode but didn't see any effect.
Nadav
Hi Nadav!
Yes beamsplitter coatings can be defined in mixed-mode. The main limitation is that only rays that reach the exit port will be considered. So it may remove one side of the beamsplitter. Usually beamsplitters are defined in multi-configurations.
Sandrine
