Bayer Sampling for Image Simulation
  • February 1, 2023
  • 331 views
Leduse
Is there a way to sample an image in a similar way as a Bayer sensor for the Image Simulation tool? Without making a custom Bayer slide surface for each image and imaging system?
For example: sampling an input image BMP as RGGB assuming bands 3+2+2+1, then providing the option of a raw or de-mosaiced color simulated image.
Best answer by Leduse
Hi Sandrine,
Thanks for the info! That sounds like a good approach.
I’ll read a bit more into ZPL. I think your macro uses most of the functions and syntax I would need to learn to make the Bayer code.
It will probably end up being very similar to this Matlab code I just wrote:
%import image
colorimg=imread('park.jpg');
dim=size(colorimg);
xpix=dim(2);
ypix=dim(1);
%These are placeholders for now, I would update them for color filter transmission + QE estimates
rimg=colorimg(:,:,1)*0.2126;
gimg=colorimg(:,:,2)*0.7152;
bimg=colorimg(:,:,3)*0.0722;
%rggb
for n=1:ypix
    for m=1:xpix
        if mod(n,2)==1
                    %r
                    if mod(m,2)==1;
                    raw_mosaic(n,m)=rimg(n,m);
                    %g
                    else
                    raw_mosaic(n,m)=gimg(n,m);
                    end
        else
                    %g
                    if mod(m,2)==1;
                    %b
                    else
                    raw_mosaic(n,m)=bimg(n,m);
                    end
        end
    end
end
subplot(1,2,1)
imagesc(colorimg), axis tight, axis equal, axis off, title('Unfiltered Color Image')
subplot(1,2,2)
imagesc(raw_mosaic), axis tight, axis equal, axis off, colormap gray, title('Bayer Filter Sim')
+1 on this suggestion
Hi @Leduse!
Thank you for sharing this idea. Ideally it would be nice to do this in the API but unfortunately the Image Simulation is not currently fully implemented in ZOS-API.
However I think ZPL could work. I did a macro that makes a cross section of the result of the image simulation here:
Based on this, I am thinking that we could do a Bayer sensor. I have added a link to Wikipedia since I had to check (https://en.wikipedia.org/wiki/Bayer_filter).
All the options are available via MODIFFYSETTINGS.
Let me know if you think that will help and happy to make an example if needed.
Leduse
  • February 11, 2023
Hi Sandrine,
%import image
dim=size(colorimg);
xpix=dim(2);
ypix=dim(1);
%rggb
for n=1:ypix
    for m=1:xpix
        if mod(n,2)==1
                    %r
                    if mod(m,2)==1;
                    %g
                    else
                    end
        else
                    %g
                    if mod(m,2)==1;
                    %b
                    else
                    end
        end
    end
end
subplot(1,2,1)
subplot(1,2,2)
