Balancing diffraction limit performance and magnification in the system
  • May 23, 2021 8:01 PM UTC
  • 120 views
How can the design be further optimized to handle constant magnification (4.5x) and field spot size ( < 2um) for tilted and non-tilted object configurations in a single design? Attached is a MWE. The system is not optimized for diffraction limit because of the acute surface bends in the front end optics thus resulting in larger SPHA through the propogation path.
- The optics are restricted to mechanical layout as shown below.
- How to define spot radius merit for each field individually in MFE?
Hi
I think you will find some interesting tools in that learning path: https://my.zemax.com/en-US/learning-paths/imaging-system-fundamentals/
Let us know if you need further help.
Sandrine
