"Arithmetic operation resulted in an overflow" Pop Up Error
  • Nov 8, 2023 8:48 PM UTC
  • 142 views
Michaelkm8
          I am trying to use the Generate Radiant Source Model feature in 22.3 and I am getting an error when I try to generate rays.
I have the .rsmx ray source file from CREE and I manually interpolated their spectral data and put it in a .spcd file.
When I try to generate the rays I get the error in the subject.
Any help is greatly appreciated.
Thank you.
Best answer by Michaelkm8
OK so I took a closer look at the interpolated values in the .spdc file I created and I had a duplicate 0.445 um value.  This caused the error and the ray file now comiles.
Michaelkm8
  • Nov 8, 2023 8:50 PM UTC
Here is the spectrum file I made.
Michaelkm8
  • Nov 8, 2023 9:47 PM UTC
