An array of hundreds even thousands sphere mirrors
  • Jun 17, 2021 2:26 PM UTC
  • 106 views
Hi~I want to make an array of hundreds even thousands sphere mirrors. Each sphere mirror(about 5000mm in radius  and 80mm in diameter) has it's own coordinate and tilt  angle. I should input each sphere mirror in non-sequential component editor one by one?   Is there a fast way to model this?
Many thanks~
Hi, not sure what you want to model, but if you have a signifcant number of items to fill into zemax, use the ZOS-API. There are some nice examples which show you how to populate a Zemax file and save it. Alternatively use a macro in ZPL. I recommend the ZOS-API which might be slower to learn at first but reaps rewards in usefullness afterwards.
Ross
