Alignment of Coordinate System between FEA and STAR
  • Jan 23, 2024 8:13 AM UTC
  • 268 views
yuan.chen
One of the frequent challenges that can occur when using several products during your multiphysics simulation analysis is a mismatch between coordinate systems. Different engineering teams can use tools that use a different Global Reference Coordinate Frame. This leads to a more complicated workflow when different aspects of the project are brought together into one location. One option is to halt the process, go back to the team member, and request a new dataset with an updated coordinate system. Delays can stack up leading to missing project delivery dates. Oftentimes though, you can perform some simple steps to align the coordinate systems to continue progressing and avoid stopping your workflow.
Here we demonstrate some steps you can take when working in Space Claim to match a STEP export from Ansys Zemax OpticStudio into a CAD assembly in an AR/VR headset system. Many thanks to Matthias who figured this out.
yuan.chen
  • Jan 23, 2024 8:15 AM UTC
Export as CAD with stop surface set as global coordinate reference
Import the generated CAD file on system level in Spaceclaim
Activate this component.
 Select this one, hit control C and control V
Check if a new origin at the global coordinate system is inserted
Hide unwanted geometry to have a better visibility.
Rotate the coordinate.
After rotation, move the part to the desired position.
Rename the current coordinate and delete the imported one, for example, Zemax GCRS and select it when we export data.
