About field height in image simulation
  • Sep 24, 2021 3:30 AM UTC
  • 1408 views
Dear all,
I’m confused with the field height setting inside the image simulation tool box. What is the appropriate field height should I set to my system?
For example, my system has two field points ((0, 700), (0, -700)), defined by object height in the field editor. What is the appropriate size for me to set the field height in the image simulation tool? Should it be 700 or 1400?
Thanks in advance.
Daoming
Best answer by David
Sandrine provided a good answer to a similar question here
  • Sep 24, 2021 9:31 PM UTC
