What is the best way to reference a surface or object in ZPL?
  • February 14, 2019
  • 422 views
Allie
  • 343 replies
What is the best way to reference a surface or object in ZPL so that the macro still works even when the numbering changes because surfaces/objects are inserted or deleted?
Best answer by Allie
Many macros are simple and straight to the point, so setting easy-to-remember variables is the best practice:
a = THIC(10)
b = RADI(11)
In this case, the variable 'a' is assigned the value of the thickness of surface 10, and 'b' is assigned the value of the radius of curvature of the following surface. But what if you add or delete a surface before surface 10? The numbering in the editor will update, and the new surface 10 will not be the one you wanted. One solution is to ask every time the macro runs:
INPUT "What surface do you want to use", my_surface
a = THIC(my_surface)
b = RADI(my_surface + 1)
But this gets tedious if you run the macro several times without changing the surface numbering. So we try utilizing a variable:
my_surface = 10
Now you only have one line to edit in the macro when surfaces change. But that's still a bit tedious.
The best thing to do is to give the surface a unique comment, like "target" for example, and then use the SURC() function:
my_surface = SURC("target")
SURC(A$) finds the first surface where the comment string is the same as A$ and returns its surface number. (In the non-sequential component editor use OBJC() instead)
my_object = OBJC("target")
This simple structure ensures that your macro always finds the intended surface or object. Note that if no surface/object has the target string set as a comment, the functions will return the value -1. It's simple to add a test to bullet-proof your code:
IF (my_object == -1)
PRINT "Target object not found"
END
ENDIF
Allie
  • 343 replies
  • February 14, 2019
a = THIC(10)
b = RADI(11)
my_surface = 10
END
ENDIF
