Modeling DOE Pattern/Image Generation using POP
  • December 29, 2022
  • 10 replies
  • 2162 views
This is a brief description of my recent experience using POP to model diffractive optical elements that may be of some interest to other users.
It is well-known that Diffractive Optical Element (DOE) technology can be used to generate custom intensity patterns or images based on coherent optics.  For example, illumination of properly constructed phase elements (i.e., DOEs) by a coherent laser beam can produce interesting intensity patterns in the far field.  Anyone who has walked the exhibit hall at Photonics West has surely seen examples of this.  Various techniques can be employed to design a DOE, with the Iterative Fourier Transform Algorithm being one popular scheme (see, e.g., F. Wyrowski and O. Bryngdahl, “Iterative Fourier-Transform algorithm applied to computer holography,” JOSA-A 1988).
Here is a brief description taken from the Holoeye website:
Modeling DOEs in OpticStudio is possible by using Physical Optics Propagation (POP).  One can envision two possible approaches: (1) model a phase-only DOE by using a Grid Phase or Grid Sag surface, or (2) mimic the output of the DOE by constructing a custom ZBF file to use as the source field.  I find the first approach is subject to a few potential problems, while the second approach seems to work quite nicely.  Some details associated with the first approach (Grid Phase/Sag surface) can be found here:
Here’s an example of the second approach based on a ZBF source file that defines a beam leaving the front focal plane of a lens (where the DOE is assumed to be located), and propagating to the back focal plane where the Fourier transform of the source field is found.  The complex field defined by the ZBF file has a Gaussian intensity profile and a phase distribution calculated to produce the Stanford University logo in the Fourier plane.
If the paraxial lens is replaced by a simple plano-convex lens, a degradation of the image quality due to spherical aberration is observed.
Presumably more complicated optical paths, such as for near-eye display, or perhaps a path that includes spatial filtering, can also be simulated.
Shay
  • June 23, 2024
Hi Jeff,
Thank you for sharing your simulation and information. If we want to use the phase light modulator in an optical setup which means the beams are reflected by PLM, can still we use ZBF for CGH simulation?
  • June 23, 2024
Hi Shay,
Yes, the ZBF file allows you to define the optical field leaving the the SLM/CGH for either transmissive or reflective devices.  If aberrations of the illumination beam are important, they would need to be included in the ZBF file, or you could consider using the Grid Phase approach with the incident field defined by propagation through the prior surfaces.
Hey @Jeff.Wilde , have you used the Optically Fabricated Hologram to create the phase masks at all?
Shay
  • June 25, 2024
Thanks for your answer. Could you please share your .zbf file?
  • June 25, 2024
@Shay :  Unfortunately I’m not at liberty to share the ZBF file because it was created by a student as part of their final project.  However, the help guide describes the available file format options.  You can first try something simple, like a quadratic phase function to mimic a weak thin lens, then once working, go for a more complicated pattern.
  • June 25, 2024
Hi @Mark.Nicholson:  In the past I’ve used the optically fabricated hologram to model, well... an optically fabricated hologram -- in which the recording medium only responds to intensity, so a fringe pattern is required to capture the phase.  However, with an SLM, a complex pixelated pattern (transmittance or reflectance) can be directly displayed.  So for CGH/DOE purposes, the user typically just programs the pattern so that uniform illumination by a coherent plane wave produces the desired complex optical field leaving the SLM (no fringe pattern required; the SLM pattern is directly imprinted onto the plane wave).
Sina.Soleymani
Hi @Jeff.Wilde I am wondering what would be the option to simulate the SLM or other pixelated phase delay surfaces considering the pixilation into account as well (simulating according to the dimensions of the each phase delay pixel). Do you think considering this in Zemax is possible? or maybe due to the calculation method in zemax it is not going to have a significant impact on the results?
Sina
  • July 29, 2024
Hi @Sina.Soleymani,
Yes, you should be able to include the finite SLM pixel size in a Zemax POP simulation by having multiple identical samples for each pixel.  I would expect that 4x4 or 5x5 samples per pixel would probably suffice.  This can be incorporated into the starting ZBF file that represents the optical field leaving the SLM.  Depending on the pattern that you are trying to create with the SLM, including the pixelation may be important in order to see sampling artifacts.
ncathy93
  • July 30, 2025
Hi Jeff,
Thank you for sharing and explaining this.
I have grid sag file of a DOE, provided by a supplier and it does not work properly with POP (but seems to give a correct shape with Footprint Diagram). I already changed the optical properties of the Output Pilot radius into “Plane”.
Do you know if it is easy to transform a grid sag file into a ZBF ?
For information, the DOE transforms a Gaussian beam into a top-hat beam and works in reflection (so I put MIRROR as material).
Thank you in advance.
  • July 31, 2025
@ncathy93:
Without seeing the grid sag file or knowing more about the problem you observe, I can’t say much.  However, you can look at the phase of the surface in POP to see if it makes sense as a check to ensure the file imported properly.  Perhaps the supplier can help.
