Hello I have a license for basic version of OpticStudio. I need to apply an apodization filter to a surface in order to program the transmission to be a Gaussian function. But it seems that the 'filter' type of surface is only available in the premium version. Is there any substitute for this function that I can use? Thank you.
substitute for surface apodization in basic version
Hi Manuel
User-defined surfaces are only available in the Professional and Premium editions of OpticStudio.
But you can define a Gaussian apodization via the System Explorer...Aperture:
Let us know if that helps.
Sandrine
Hi Sadrine,
This in indeed what I have been using for generating a Gaussian input beam.
What I was trying to do is to further filter the transmission by a Gaussian function after shaping the beam with some optics. Is this not doable with basic version?
Hi Manuel
Yes the user defined called us_filt* would have helped. We also have a slide surface but it is not available in standard mode either.
I can send you a message with the name of your account manager if you'd like to have a quote to upgrade?
Sandrine
Hi Sandrin,
I took the aperture data,
N.A=0.08 G=1
What I get here is an intencity profile cut at the edges not for normal gaussian .
So I put G=2 the profile i get nice narrow gaussian profile at geometric image analysis .what is the mathematical relationship to the numeric key size, what angle size do I
need or NA?
i(roe)=exp-(roe)^2 × theta^2)
Sorry for the very late reply but in the help file we define the apodization as:
![](https://uploads-us-west-2.insided.com/zemax-en/attachment/3d633286-6bc4-4a2b-aab2-b692509ef284.png)
where A is the amplitude, G the apodization factor and ρ the normalized pupil coordinate.
