Modelling supergaussian beam
  • May 4, 2023
  • 345 views
GiovanniCich
Hello everyone,
I have to simulate the propagation of a supergaussian beam with a M2=46.9 through the Physical Optics Propagation but I don’t know how to define the beam. I tried to use the top-hat beam, which is a good approximation for my purpose, but its divergence (in POP) does not match the divergence of a supergaussian beam. Thanks for your help.
Best answer by Kevin Scales
POP does not take M2 directly as a parameter, and Mark's observation is relevant here. POP may not give you useful information in cases like that if it could. A rule of thumb is that POP works best when geometric rays do not, and when POP doesn't work well the aberrations usually dominate anyway.
Hey Giovanni,
If the beam has M^2~47, then it expands 47 times faster than a diffraction limited Gaussian. Why not just use rays?
  • Mark
Kevin Scales
  • May 9, 2023
