Python Reading Writing Binary Files (ZRD, ZBF, DAT, SDF)
  • August 1, 2022
  • 16 replies
  • 3394 views
Michael Cheng
The download contains 3 Python scripts:
  • a script to read / parse a ZRD (Zemax Ray Database) file
  • a script to read / parse a Binary ZBF (Zemax Beam File) file
  • a script to read / parse a Binary DAT / SDF Source File
Click here to download
2022/01/01 1.0 - Creation
Daniel
  • August 1, 2022
Hi there,
I’m looking through the script for parsing ZRD files. I see that a lot of values are unpacked as “d” meaning a C double. When I look in the Zemax documentation for ZRD files, it says that the uncompressed ZRD is stored with 64-bit doubles but that the compressed ZRDs are stored with 32-bit floats.
Is the ZRD parsing script meant to work for compressed files?
Cheers,
Michael Cheng
  • August 2, 2022
Hi Daniel,
Thank you for discussion. Unfortuantely, this script only works with uncompressed ZRD. The format in the compressed ZRD is IP that cannot be shared publicly.
I suggest you read the compressed ZRD using ZOS-API. You can find a good example in the Zemax installation in \Documents\Zemax\ZOS-API Sample Code\Python\PythonStandalone_05_Read_ZRD_File.py.
I hope this helps.
Please let me know if you have any questions.
Thank you.
Jimmy Zheng
  • August 23, 2022
Thanks Michael, do you happen to have the matlab version as well
Michael Cheng
  • August 24, 2022
Hi Jimmy,
Thank you for checking!
Unfortunately I don’t have an example for MATLAB. I think the key point is you need to know how to read/write a binary file and parse it as double or string in MATLAB. I just had a quick search and can see corresponded tutorial. With this reference, I think it’s possible to convert the code in Python to MATLAB.
https://www.mathworks.com/help/matlab/ref/fread.html
I’m sorry for inconvenience. Please let me know if you have any further question. Thank you!
Michael
Jimmy Zheng
  • August 24, 2022
Hi Jimmy,
Michael
Cool bean, I can’t seem to be able to download the python script from your post.
Michael Cheng
  • August 25, 2022
Hi Jimmy,
Your account need to associated with an active Zemax license in order to access the download link. You can find more information in this post:
Please do not hesitate to let me know if still have any question.
Thank you.
Jimmy Zheng
  • August 25, 2022
Hi Jimmy,
Thank you.
I have an active license, do I need to open a support ticket?
Michael Cheng
  • August 25, 2022
Hi Jimmy,
Yes, that’s a little weird if you are End User of a supoprted license but cannot use the following link.
Please feel free to send a support ticket so that we can help to see if there is any issue in your account and send the file directly to you in the meantime.
Thank you.
Jimmy Zheng
  • August 26, 2022
Hi Jimmy,
Thank you.
Thanks Michael. Allie fixed it
Alex.Tripsas
  • Visible
  • September 1, 2023
Hi Michael,
This is great!  Thank you for making this.  However, for reading the ZBF files, it looks like there’s just header information.  Have you done any work to extract the actual E-field data?
Michael Cheng
  • September 2, 2023
Hi Alex,
Yes, sorry confusion. Unfortunately, I didn’t made the code for reading the part of E-field matrix. However, this code example demonstrates how you can read binary data and parse them to a meaningful number in Python. Using the same command, you can follow the description in the Help file as below to read the rest of the matrix data.
The Analyze Tab (sequential ui mode) > Laser and Fibers Group > About Physical Optics Propagation > Defining the Initial Beam > File (defining the initial beam) > Zemax Beam File (ZBF) Binary Format
Please let us know if you have any questions.
Thank you!
Kris
  • November 1, 2024
I have run into very similar need for a fully-functional Matlab code @Jimmy Zheng. Furthermore, I needed a much more powerful tool for path grouping and analysis than what the native Zemax can provide. I thus came up with my own fully independent and fully operational Matlab function to do this. Needless to say, @Michael Cheng Python code served as an inspiration how to write the raw data loading part. I am delighted to share my function on https://community.zemax.com/star-module-user-group-85/matlab-script-to-group-rays-from-zrd-file-to-separate-paths-5430
Hope you find it useful folks!
jesusmunozjmj
Thank you for the scripts to read .ZRD files. I was able to get them working with a test optical system from Zemax, but I ran into an issue when trying to use the dictionary with a different .zmx file from another optical system ("error: unpack requires a buffer of 8 bytes"). Are there any limitations I should be aware of, or should it work with any optical system?
Jesús Muñoz
Kris
  • November 12, 2024
Strictly speaking, it can only work with uncompressed .ZRD files and version 2002. Maybe there is an issue with that?
jesusmunozjmj
Hi!
Thank you for your help. I didn’t realize it, but the ray tracing was being done with the ZRD data compression mode on. Do you know if there’s an attribute in the `ray_trace` function in Python to generate an uncompressed version of the ZRD during tracing? For example, with polarization: `NSCRayTrace.UsePolarization = True`.
Jesús.
Kris
  • November 14, 2024
Unfortunately, I never used the Zemax API so far, so I cannot tell. I always performed all operations manually, i.e. within Zemax environment.
