Optimization ranges using CPAR and COMP
  • 11 January 2024
  • 55 views
I am working on a tolerance script that uses different surface optimizations (thickness as well as tilts) on its components.
I am using the CPAR and COMP commands, but there is a constraint in the maximal optimization range. Is there a way to set this range in the script? I can try to use the merit function to set the limits, but seems too convoluted.
Userlevel 7
Badge +3
Can you enforce the constraint in the tolerancing merit function? The only other thing I can think of is using a solve (including a ZPL solve) in the Lens Data Editor as a way of enforcing the constraint.
Thank you very much Mark.
I was considering constraints in the merit function, but a solve can be a more elegant solution.
