Converting CAD data of the TIR lens into the parametric surface for optimization in NSQ mode
nikitasatcik
It is common for illumination design to have complex shapes which are difficult to describe by a mathematical formula. For example, custom collimators, waveguides, reflectors, and so on could be represented by freeform curves. When such optical components are designed in a CAD program, we can't optimize their shape in Zemax after importing CAD files.
To overcome this issue, I provide an example of how to convert CAD data of a TIR lens into a parametric surface and optimize it for light collimation.
In this example I’m using TIR lens. It consists of TIR surface and refractive surface, as shown below.
Reference: Pencil of Rays
First, we will fit TIR surface.
Zemax has a Freeform Z object, which is formed by drawing a cubic spline curve through a series of points in the YZ plane:
Our target is to retrieve these YZ pairs from a solid model cross-section via cubic spline interpolation. Spline interpolation can be done in python using scipy.interpolate.CubicSpline(Z,Y):
Cubic Spline Interpolation
After interpolation, we choose the number of points for Freeform Z. I found it is sufficient to set this value between 10 to 20 points based on the curvature complexity.
Second, I use aspherical surface to fit a refractive part of TIR lens.
Next, we can get a complete parametric representation of TIR lens by Freeform Z and Aspherical lens:
CAD data fitted by Freeform Z and aspherical lens
Finally, to optimize TIR lens for light collimation, I use NSRA operands targeting Y-cosine to be zero:
TIR lens optimization
This method can be applied to any CAD data with rotational symmetry. For non-symmetrical lenses, we can apply similar approach by using Grid Sag.
Mykyta
Hi @nikitasatcik !
I think you may have forgotten the attachment.
nikitasatcik
Hi, @Sandrine Auriol.
I have uploaded a python script on github:
https://github.com/nikitasatcik/cad-interpolation/tree/master
This simple script performs interpolation of a solid model cross-section via cubic splines:
  1. First, you have to get your CAD model cross section and save it as a CSV file.
  2. Next, use get_xy_curve_from_csv(path) function to read the CSV file containing pairs of x and y values.
  3. Then create a cubic spline interpolation object cs.
  4. Finally, use  plot_xy_curve(x, y, cs, npts) method to visualize the data and the fitted curve.
There are many methods how to get a cross-section of  a solid object. It depends on the CAD program you’re using. I prefer to obtain cross-section as control points of a NURBS curve:
Hope this will help. Let me know if any other details are needed.
Best Regards,
Mykyta
HI @nikitasatcik! I have moved your post to the Code Exchange. I hope that is ok for you.
