Converting CAD data of the TIR lens into the parametric surface for optimization in NSQ mode
  • Apr 28, 2023 9:08 AM UTC
  • 1237 views
nikitasatcik
It is common for illumination design to have complex shapes which are difficult to describe by a mathematical formula. For example, custom collimators, waveguides, reflectors, and so on could be represented by freeform curves. When such optical components are designed in a CAD program, we can't optimize their shape in Zemax after importing CAD files.
To overcome this issue, I provide an example of how to convert CAD data of a TIR lens into a parametric surface and optimize it for light collimation.
In this example I’m using TIR lens. It consists of TIR surface and refractive surface, as shown below.
Reference: Pencil of Rays
First, we will fit TIR surface.
Zemax has a Freeform Z object, which is formed by drawing a cubic spline curve through a series of points in the YZ plane:
Our target is to retrieve these YZ pairs from a solid model cross-section via cubic spline interpolation. Spline interpolation can be done in python using scipy.interpolate.CubicSpline(Z,Y):
Cubic Spline Interpolation
After interpolation, we choose the number of points for Freeform Z. I found it is sufficient to set this value between 10 to 20 points based on the curvature complexity.
Second, I use aspherical surface to fit a refractive part of TIR lens.
Next, we can get a complete parametric representation of TIR lens by Freeform Z and Aspherical lens:
CAD data fitted by Freeform Z and aspherical lens
Finally, to optimize TIR lens for light collimation, I use NSRA operands targeting Y-cosine to be zero:
TIR lens optimization
This method can be applied to any CAD data with rotational symmetry. For non-symmetrical lenses, we can apply similar approach by using Grid Sag.
Mykyta
Hi @nikitasatcik !
I think you may have forgotten the attachment.
nikitasatcik
  • May 17, 2023 2:57 PM UTC
Hi, @Sandrine Auriol.
I have uploaded a python script on github:
https://github.com/nikitasatcik/cad-interpolation/tree/master
This simple script performs interpolation of a solid model cross-section via cubic splines:
  1. First, you have to get your CAD model cross section and save it as a CSV file.
  2. Next, use get_xy_curve_from_csv(path) function to read the CSV file containing pairs of x and y values.
  3. Then create a cubic spline interpolation object cs.
  4. Finally, use  plot_xy_curve(x, y, cs, npts) method to visualize the data and the fitted curve.
There are many methods how to get a cross-section of  a solid object. It depends on the CAD program you’re using. I prefer to obtain cross-section as control points of a NURBS curve:
Hope this will help. Let me know if any other details are needed.
Best Regards,
Mykyta
HI @nikitasatcik! I have moved your post to the Code Exchange. I hope that is ok for you.
