Python Zemax to SPEOS coating converter
  • January 13, 2023
  • 170 views
This example is a Python script to convert Zemax coatings to Speos coatings. The script is available here.
https://github.com/ansys/optical-automation/blob/main/ansys_optical_automation/application/example_convert_coating_zemax_to_speos.py
The user inputs are:
For each coating + substrate, the software will create a Speos coating. Then the script will combine the two Speos coatings into a .bsdf180 file. The script is using the Transmission vs Angle analysis from OpticStudio.
For more information about Ansys optical_automation, click here.
Be the first to reply!
