Use X-axis Reference in ZEMAX
  • Jun 17, 2023 2:28 PM UTC
  • 93 views
haihw
在ZEMAX中,物理光学传播的功能里面空间余弦矩阵是怎么得到的,物理光学传播中光束的Y轴是怎么定义的,或者“镜头编辑器→物理光学→采用X轴参考”是什么意思?
In ZEMAX, how is the space cosine matrix obtained in the function of physical optical propagation, how is the Y-axis of the beam in physical optical propagation defined, or what does "lens editor → physical optics → Use X-axis Reference " mean?
