ZPL macro: Where can I find the list of "NSC_" for all the object types?
  • November 5, 2021
  • 405 views
Hello Community,
I am working on making a macro and would like to know how I can set the object type, for example, Source Two Angle.
There is only one example that Standard Lens to be described as “NSC_SLEN” in the ZEMAX Manual and I cannot find the information for other objects.
Your support would be greatly appreciated.
Thank you.
Kind  regards,
Ryo
Best answer by Allie
Thanks David! A full list is also available in the Help System file “The Programming Tab...About the ZPL...KEYWORDS (about the zpl)...SETNSCPROPERTY (keywords)” as shown below.
  • November 5, 2021
Hi Ryo,
The description of SETNSCPROPERTY says:
The names for each object type are listed in the Prescription Report for each object type in the NSC editor
If you put a Source Two Angle in a Non-Sequential System, and open Analyze..Prescription Data and scroll inside that file to your Source Two Angle object you can find its keyword: NSC_SR2A.
Let me know if that helps.
Allie
  • November 5, 2021
  • November 5, 2021
Thanks Allie, I didn’t scroll down enough!
  • November 5, 2021
Hello David and Allie,
Thank you very much for your responses and they helped me a lot to save time!
b.r.
Ryo
