ZPL Improvements
  • Sep 4, 2024 10:24 AM UTC
  • 291 views
Masato.Aketagawa
The program in the following file assigns random values ​​to the specified Zernike terms. This ZPL works in non-sequential mode but not in sequential mode.
Where do I need to modify it to make it work in sequential mode?
Lens data is attached in another file.
@Masato.Aketagawa
The macro sets non-sequential parameters using the keyword SETNSCPARAMETER. In sequential mode, to set a parameter, you would use SETSURFACEPROPERTY or SURP. The syntax looks like so (for a parameter):
SURP surface, PARM, parameter_value, parameter_number
surface should be the surface number of the Zernike surface, parameter_value is the random value you want to assign, and parameter_number is the column number of the corresponding Zernike term you want to assign. If you have a doubt about the parameter_number, add a Standard Surface before the Zernike surface, and click in the cell just above the Zernike term you are interested in.
4th Order Term cell selected
Selecting a cell from a Standard Surface just above the 4th Order Term cell reveals the column number Par 2(unused). This means this column is parameter_number = 2.
I hope this helps.
  • Sep 4, 2024 2:52 PM UTC
@Masato.Aketagawa
I hope this helps.
