ZOS-API Setting Pick Ups
  • Sep 28, 2022 5:19 PM UTC
  • 605 views
Does anyone have an example of setting pickups via the ZOS api in NSC mode?
for i in obj_list:
    obj = NCE.GetObjectAt(i)
    obj.Xposition.SetPickupfromObject(1) ??? something like this
I have over 100 lines in the editor I’d like to set to pickup a position off of an existing object, and manually clicking all of them is tedious.
Thank you,
Jason
Hi Jason,
To complement @yuan.chen‘s answer, here is a more specific code:
# This is your non-sequential object
obj = TheSystem.NCE.GetObjectAt(2)
# Create a pick-up solve type from this object
pickup_solve = obj.XPositionCell.CreateSolveType(ZOSAPI.Editors.SolveType.ObjectPickup)
# Adjust the solve settings
pickup_solve.Object = 1 # This is the object to pick-up from
pickup_solve.ScaleFactor = 2.0
pickup_solve.Offset = 3.0
pickup_solve.Column = ZOSAPI.Editors.NCE.ObjectColumn.XPosition
# Apply the solve
obj.XPositionCell.SetSolveData(pickup_solve)
You can pick-up from other columns, and you’ll find the available ones in the Syntax Help File:
Comment
RefObject
InsideOf
XPosition
YPosition
ZPosition
TiltX
TiltY
TiltZ
Material
Par1
Par2
Let me know if this helps. Take care,
yuan.chen
  • Sep 29, 2022 1:46 AM UTC
Hi Jason,
Sorry for my short reply. I have to do many clean-ups before I go for vacation.
Here is a sample code for sequential mode. You can find something similar in non-sequential.
surf3 = TheSystem.LDE.GetSurfaceAt(3)
surf6 = TheSystem.LDE.GetSurfaceAt(6)
ParameterPickup = surf6.GetCellAt(12).CreateSolveType(ZOSAPI.Editors.SolveType.SurfacePickup)
ParameterPickup._S_SurfacePickup.Surface = 3
ParameterPickup._S_SurfacePickup.ScaleFactor = -1
ParameterPickup._S_SurfacePickup.MakePickupFromCurrentColumn()
The code is part of sample code 7
  • Sep 29, 2022 12:36 PM UTC
Hi Jason,
# Apply the solve
Comment
RefObject
InsideOf
XPosition
YPosition
ZPosition
TiltX
TiltY
TiltZ
Material
Par1
Par2
yuan.chen
  • Sep 29, 2022 1:12 PM UTC
Many thanks! @David.Nguyen
@yuan.chen  @David.Nguyen
Thank you both for the quick response.
This is exactly the syntax I was looking for.
