Hi all,
I’m trying to use ssag operand to obtain the surface sag in sequential mode. I’m ok with using it in the merit function editor, however, as I have a lot of sampling points, manually inserting ssag function is a real pain. Is there any method to use SSAG in the ZPL Marco where I can write my own loop?
Best wishes
Daoming
Hi Daoming,
Try this, and let me know if this works for you:
# Operand settings (SSAG)
type = 11
surf = 2
mode = 3
x_set = 4
y_set = 5
of_ax = 6
remove = 7
target = 8
weight = 9
# Loop over 10 iterations
FOR ii, 1, 9, 1
    # Select rows in which to insert the MF operand
    row = 1
    # Insert new MF operand
    INSERTMFO row
    # Change operand settings
    SETOPERAND row, type, "SSAG"
    SETOPERAND row, surf, 2
    SETOPERAND row, mode, 0
    SETOPERAND row, x_set, 0.1
    SETOPERAND row, y_set, 0.3
    SETOPERAND row, of_ax, 1
    SETOPERAND row, remove, 1
    SETOPERAND row, target, 12
    SETOPERAND row, weight, 0.5
NEXT
Hi David,
I’m sorry for the late reply. It works!!
Thank you!
Best wishes
Daoming
