float to integer
  • September 23, 2024
  • 232 views
Is there a way to change variable from float to integer?
I want to use it to write list of polygons in loop:
for i:n:
polygon_name 1.pob
polygon_name 2.pob
polygon_name 3.pob
In other words, i dont want something like that:
Nadav
Best answer by Sean Turner
Use the FORMAT keyword to change to an integer.
FORMAT m INT
The optional keyword INT indicates the value should be first converted to an integer and printed in integer format using the number of places specified by m.
Sean Turner
FORMAT m INT
Hi Sean,
It works,
Thank you very much,
Nadav
