ZOSAPI changing settings
  • May 6, 2024
  • 8 replies
  • 470 views
I try to use code from example e23s08_py for changing settings of analysis window, but meet error with
ray_settings.Field.UseAllFields()ray_settings.Wavelength.UseAllWavelengths()
Traceback (most recent call last):
  File "C:\Program Files\JetBrains\PyCharm 2023.1.2\plugins\python\helpers\pydev\pydevconsole.py", line 364, in runcode
    coro = func()
  File "<input>", line 126, in <module>
AttributeError: 'IAS_' object has no attribute 'Field'
    ray = TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.RayFan)
ray_settings = ray.GetSettings()
ray_settings.NumberOfRays = max_rays / 2
ray.ApplyAndWaitForCompletion()
ray_results = ray.GetResults()
but even if I supress them   ray_settings.NumberOfRays = 0
dont change default value, silently.
@Aleksandr.Makarov
If you are using pythonnet > 2.5.2, then you need to be aware of this:
In short, your code will almost work if you add .__implementation__ after your GetSettings():
ray_settings = ray.GetSettings().__implementation__
I am saying almost, because there’s something else you need to be cautious about. The number of rays need to be an integer. Therefore, I’d suggest to use:
ray_settings.NumberOfRays = int( max_rays / 2 )
or any other form of casting to integer.
  • May 7, 2024
@Aleksandr.Makarov
How I can change wave in analysis window?
I try few different but all of them was not correct: gee_settings.IAS_Wavelength = ZOSAPI.Analysis.Settings.EncircledEnergy.IAS_GeometricEncircledEnergy.Wavelength(1)
but it not work and I not sure how find proper key words for this case
    gee = TheSystem.Analyses.New_Analysis(ZOSAPI.Analysis.AnalysisIDM.GeometricEncircledEnergy)
gee_settings = gee.GetSettings().__implementation__
gee_settings.RadiusMaximum = 50
gee_settings.SampleSize = ZOSAPI.Analysis.SampleSizes.S_32x32
gee_settings.ReferTo = ZOSAPI.Analysis.Settings.EncircledEnergy.ReferToTypes.Centroid
gee_settings.Type = ZOSAPI.Analysis.Settings.EncircledEnergy.EncircledEnergyTypes.X_Only
gee.ApplyAndWaitForCompletion()
jwbeenakker
Your problem seems indeed to be related to a compatibility issue of the ZOSAPI with modern python versions.
If you don’t want to gain experience with casting variables between python and .NET,  ZOSPy could be a solution for you, as it performs all these steps automatically. It’s available through pypi or anaconda, and has quitea nice documentation
ZOSpy support all features of ZOS API? I cannot find GeometricEncircledEnergy
jwbeenakker
Dear Aleksandr,
The complete ZOSAPI can be accessed through ZOSPy, and ZOSPy will perform the conversion for all these functions (see https://zospy.readthedocs.io/en/latest/codecs.html  for a more elaborate explanation).
For some functions, ZOSPy also includes a more “easy”/pythonic way of performing an analysis, but not all possible Optic Studio analyses are (yet) included. If you require another analysis, you can modify one of the analyses that are already included as a template (see for example the polarisation analysis which has been contributed by one of the ZOSPy users).
If you have made something that works nice, please consider contributing it, so your fellow OpticStudio users can benefit from it.
gee_settings.Wavelength.SetWavelengthNumber(1)
David.Nguyen how I can change settings in loop?
I tried all separators. between X and Only but no success
type_s = ["X Only", "Y Only"]
for type_ in type_s:
gee_settings.Type = ZOSAPI.Analysis.Settings.EncircledEnergy.EncircledEnergyTypes[type_]
@Aleksandr.Makarov
This works for me (don’t forget the usual .__implementation__):
type_s = [ZOSAPI.Analysis.Settings.EncircledEnergy.EncircledEnergyTypes.X_Only, ZOSAPI.Analysis.Settings.EncircledEnergy.EncircledEnergyTypes.Y_Only]
my_analysis = TheSystem.Analyses.New_GeometricEncircledEnergy()
my_analysis_settings = my_analysis.GetSettings().__implementation__
my_analysis_settings.Type = type_
my_analysis.ApplyAndWaitForCompletion()
