Zemax C++ ZOS API COM Error
  • February 24, 2025
  • 136 views
Imaad
Hi all,
I am trying to run a simple standalone c++ application which gives  “Microsoft C++ exception: _com_error at memory location” The error is on line 29
// Create the initial connection class
IZOSAPI_ConnectionPtr TheConnection(__uuidof(ZOSAPI_Connection));
Does someone have an idea on what could be the issue?
I prefer to use C++ as I have to integrate other code with it.
Thank you.
Best answer by Imaad
Hi all,
It seems I have corrupt graphics drivers that are causing this issue. The code works fine on other system.
Imaad
  • February 25, 2025
Hi all,
